apps for cars
  • apps for cars
    so after getting some help from hexxamillion (thanks ) and getting started with my samsung car project I would like to ask what apps people use in the car ,I am using carhome for the frontend and rocket player for music along woth navworld for my sat nav .
    what do you guys use and why
    I use Car home Ultra... Winamp for music and Google nav for GPS. I also have CoPilot as a backup GPS as it has offline maps.
    Sent from my Galaxy Nexus using Tapatalk 2
      Torque is probably the best dashboard app for viewing OBD and accelerometer data. It also has a map mode and can calculate 0-60 times and horsepower.
        how do you connect to the car ??
          Bluetooth ODB unit.
            Originally posted by SynC View Post
            Bluetooth ODB unit.
            http://www.ebay.co.uk/itm/Hot-V1-5-E...item2ec158a245
            like this??
              Yes, that should do the job.
                cool cheers
                  Is anybody using voice recognition? I want to be able to play tunes based on song, artist, album, random, all from voice. I'd also like to fire up GPS, and anything else I can think of. Basically a Siri for the CarPC. Anything like that?
                    Would be nice, but I wouldn't expect reliable recognition from an internal mic over road noise, music etc. Would need a good external mic, which only some tablets support.
                      I'm starting my conversion to a Android setup. Did tons of research. My tablet has AndroI stilld 4.0, soon to be Android 4. 1. YWonder ou wcan ant to make sure it has Android 3.0 and up. These versions support USB Host Mode. Which allows you to connect tons of devices.
                      1) For phone/text: Tablet Talk. Connects via BT or Wifi. I wanted to use Wifi mode, but when I started this post, I realized that when connected to 3G/4G, Wifi turns off. *Note, due to Android limitations, you have to use a BT headset posted with phone, not tablet. Since I want to use this in my car, through speakers, the Car PC will act as a kind of emulator via its BT, mic and speaker.
                      2) For GPS: tetherGPS . Also connects via BT or Wifi. I needed this because my tablet came with everything underneath the sun, but GPS.
                      3) For OBD2: Torque Pro (must be pro version to use USB) via USB OBD2. Tablet or phone must be Android 3.0 and up, and must have USB Host Mode in debugging section.
                      4) TPMS: via BT. I think they may have a Wifi mode, didn't check though since it would be only device tying up BT. Also with Android 4.0 and BT 2.1, you can connect more than one device. Anyways, the app is called TireHawk Bright+. The app is in the market. It's full version, but in demo mode. Once it detects the TireHawk unit, it will switch from demo to real. Still waiting on pricing from company. Seems to be the only Android TPMS solution. What really attracted me is that the sensors mount on the valve stems ( has anti theft feature also). So easy to install. Also has replaceable batteries.
                      That's what I got so far. Most everything else is available in Google Play Store.
                      PS: i still have my Car PC. I use it to store all media, tether 3G/4G/wifi connection to create hotspot, convert tablet audio to 7.1, create BT headset emulator. Also controls all screens, amps, and inverter.
                      As far as voice recognition, I can see if my BT headset idea works. I don't think it will since that is tethered to phone. Wonder if I can pair to 2 devices. Tablet and Phone via PC? I'll let you know.
                      Found this article, so may hold promise. I guess I have to see if BlueSoliel has the ability. HMMM, I'm going to uninstall BlueSoliel, Windows does PC speakerphone natively as far as paired to one device. If not, something on PC will. http://reviews.cnet.com/2719-7609_7-295-2.html
                      1X Ainol Novo Flame Tab
                      4X MK808b
                      3x Perixx Touchpads
                      3x 7 inch Screens
                      1X 7 inch motorized Screen
                      1x Win 7 PC
                        Hey guys, just getting into an android setup myself. Have a google nexus 7 tablet that's going in my car. Just got using the usb as OTG and charging it at the same time sorted out, now I'm focusing on the software. I'm surprised there isn't any good front ends for android since the stock front end is already mostly there... just need to be able to make the icons bigger and it's ready to go. I spent a lot of hours going through dozens of music players and right now Aalinq is the forerunner, but there are a couple others that work nicely too.
                          I find car home a good front end
                            I'm using Windows 8 alone, without any kind of frontend. I have microsoft speech recognition. with a normal mic, and some traaining, it almost always understands what i say. combined with autohotkey , and speech macros you can do wonders with your voice! (includind full control of WMP like "play artist. or play song")
                              [URL="https://play.google.com/store/search?q=car+home&c=apps"] Here are some front end options for Android. Car home ultra is what I use cause it is completely customizable. If you are planning on using a Nexus 7 then highly suggest that you update to 4.1.2 since it will allow your stock launcher to change into landscape mode. I also want to integrate one of these to my system and that is why I signed up. My idea is to use a Bluetooth camera for backup camera using this to control it or view it https://play.google.com/store/apps/d...VyYXJlbW90ZSJd not sure how well it will work. Also i use an external bluetooth GPS with this apphttps://play.google.com/store/apps/d...lkLmJ0Z3BzIl0.
