Samsung Galaxy Tab Aux Issues
  • Samsung Galaxy Tab Aux Issues
    I've done quite a bit of research on this site as well as others and have finally taken the plunge and installed a Samsung Galaxy Tab (P3113 - Rooted) into my E46.
    I utilized the OEM headunit, with aux input, which I relocated near the glovebox so that I can keep the Steering Wheel Controls.
    Now the issue I run into is, whenever I plug in the USB charger, the Aux option disappears from the head unit, no sound would come out of the headphone jack, where the Aux cable is connect.
    Whenever I unplug the USB from the power source, the AUX comes right back.
    Any help or insight into this would be greatly appreciated.
    Thanks in advance.
    Ron.
    does it not have a setting so that when you plug in it charges only ,if not i am sure tasker app will help
      Thanks for the update, I tried a few thinks with tasker but it doesn't help. I've found a solution in which I have to put 2 Cap and a Resistor on the AUX cable to enable charging and playing simultaneously.
