carnetix to power a laptop as well as charge its battery?
  • carnetix to power a laptop as well as charge its battery?
    I recently installed a carnetix p-2140 PSU and connected it to my HP nc2400's AC adapter. As mentioned in previous threads on powering laptops using the carnetix PSU some laptop AC adapter have three wires. When I tested the three wires with a multimeter I have a ground, a +5, and a +19. I am able to utilize the p-2140 to successfully power my laptop(+20 on primary out for the docking station), and External 600GB Hard drive(+12 on the secondary out). Is there anyone utilizing a carnetix to power a laptop as well as charge its battery?
    My current setup:
    2005 Camry LE
    RoadRunner 12/08 with DigitalFX 4.0 Front End
    HP nc2400 1.8ghz, 60gb HD, 2gb ram with docking station
    Lilliput Eby-701 mounted with a e-byte Double-din Dash kit
    Carnetix p-2140 PSU
    600gb WD Mybook
    Apple Bluetooth Keyboard
    Logictech Trackball
    JVC HU with Aux-in connected to carputer
    MTX Thunder 7804
    12" 1200 Watt Pyle subwoofer
    Viper 5900 Alarm with Motion Detection (NYC Must)
    Future Plans:
    Fabricate a Bezel
    PAC steering Wheel control
    HDTV
    back-up Camera
    Possible 2nd Roof mounted Screen for the rear passengers
    "Camputer - 2005 Toyota Camry LE"
    I'm not sure I understand your question. Do you have the Carnetix powering the +5, the +19 and ground into the laptop? If so, it ought to function just like it did when connected to the AC adaptor, including charging the battery.
    Want to:
      I'm guessing your laptop cannot recognize the power input and is directing all the power to the system board and not charging the battery....and having a built in ups is a big plus... I think some manufacturers can bypass this setting in the bios -not sure if you HP has the capability of that or not.
      May I ask why you chose to go with the carnetix for a laptop?
      -WarDriver-
      Server Administrator
      Outdoor Nut
      My DC to AC Inverter Mod
      My Laptop Remote Switch
        [HL] Do you have the Carnetix powering the +5, the +19 and ground into the laptop? [/HL]
        Wardriver The carnetix is currently supplying +12(for my external hard drive, and +19 and ground (to the laptop). I would probably need the additional device that supplies and third output to send the +5v to that third wire but .. again Im not 100% sure it would solve my issue.
        [HL]I'm guessing your laptop cannot recognize the power input and is directing all the power to the system board and not charging the battery....and having a built in ups is a big plus... I think some manufacturers can bypass this setting in the bios -not sure if you HP has the capability of that or not.[/HL]
        Bugbyte:
        The laptop is working just fine connected to the carnetix. I will probably solder the start-up/shut-down wire soon just trying to figure out how I can make it plug in and plug out. like some sort of male-female connector soldered to the docking station just in case.
        [HL]May I ask why you chose to go with the carnetix for a laptop?[/HL]
        because after my numerous searches of carputers setup that utilized laptops the carnetix was the highly recommended solution to power a laptop, as well as power the Touch Screen. Although I contemplated installing a POL to supply +12 to the TS LCD, and the Ext HD. It seemed like the best bang for the buck solution
        BTW Happy New year guys
          I had to sell my mac mini it would shut off when I hit bumps
          The main reason I needed the cash but still wanted to see if anyone figure how to charge a laptop battery as well as power the unit utilizing the carnetix PSU.
            you're talking about the HP barrel plug? I tried to hook up my TC4400 using the 19v and 5v as well as gnd, but it did not work properly... ran veeeery slow. The '5v' is a floating number as it's more of an ID for the adapter so that the computer runs properly. Lenovo and Dell have a similar thing.
            I just picked up an air/auto adapter that I'm going to be connecting to my CNX-1900 on the 12v rail rather than plugging in to the cig lighter.
            03 Hyundai Elantra GT {Worklog}
            HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
            RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
            cmdRR tall skin creator
            86 Pontiac Fiero SE 2m6
            possible carpc install
