How exactly do you hardwire laptop to car battery?
  • How exactly do you hardwire laptop to car battery?
    I have seen many posts and I have not come across any that actually explain how to hardwire or connect your laptop/netbook power directly to your car battery.
    If anyone has come across a post in the forum I overlooked or missed in the search,please post the link.
    I also want to know if you would still need to use a fuse in between the wiring from the battery to the laptop/netbook and if you could still keep the laptop/netbook battey connected using this power solution.
    I am researching future implementation of solar power for my eeepc in the car but want to get the basics down regarding connectivity to the car battery for now.
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Simple.
    You use an auto power adapter for the laptop.
    Positive line goes to the positive battery terminal with a fuse within a foot of the battery.
    Negative line can go to the negative battery terminal or the chassis for ground.
    How about the Wiki?
      Great! Thanks for the reply. Seems simple and straight forward. I just need to look for an auto power adapter.
      Recent Proj
      Old Proj II
      Old Proj I
        laptop power...
        I've been toying around with just hard wiring in a 600w power adapter into my trunk's 12volt outlet and then plugging in the laptop to that.
        ... it'll provide some protection through the power adapter's smart sensor so I don't end up draining the car battery.
        Plus I'm just lazy.
        Just my 2 cents.
        Sympul
        Everything is Simple to someone else...
