XENARC 700IDT touch screen menu
  • XENARC 700IDT touch screen menu
    Hi all
    This screen has a OSM = on screen menu facility, which should only come on when the button is pressed on the unit.
    However when the screen is touched a little harder the OSM appears and stays on for a few minutes.
    It can be seen in the video comming on when the corner of the screen is touched as well.
    This is annoying because while the OSM is displayed the touch screen is deactivated.
    Is there a switch somewhere that I can disable?
    This has been going on for weeks now and the unit has been back to the shop, who say they cannot find a fault.
    See it here
    I'm guessing that there's a setting in the drivers to make the on screen menu come up when you press (or press and hold?) in the upper-left corner of the screen.
    The menu comes up when you're holding (squeezing?) that corner of the screen. It appears as if that's applying pressupre to the touchkit, causing the menu to come up. The corner of the touchkit may be caught in the bezel or something, maybe?
    How about the Wiki?
