Power Acoustik lcd instalation..
  • Power Acoustik lcd instalation..
    Hello all,
    My 5.6 lcd is here, but i don't know if is better to power the lcd direct to my car batery or to the computer. I am using a regular computer with an DC - AC inverter in my car. Can i plug the lcd cables to the computer power suppy? Tanks very much for the help.
    Cyro
    I am not sure if you will be able to connect the LCD directly to the computers power supply... you may need to just connect the wires according to the instructions.... connecting directly to the PC's supply only works for certain lcds that were made to operate truly on 12vdc - i.e. the parts express 4"
      I used the computers power supply, even tho I didnt haveto I like having the screen powered behind a few more fuses etc... !
      It will most likely/definately require a 12Volt supply so the computer's PSU will be perfect.... its a cleaner and better regulated signal..
      Kain, I dont understand your point.... if the mobile screen requires 12V, it will work fine off a PSU's 12Volt output....
      Project - GAME OVER :(
