50pin connector?
  • 50pin connector?
    I'm looking at a SBC with a 50pin LCD controller onboard.
    I've read about the 31pin ->50SCSI cable trick by running various searches on this, but can't really find any explanation as to whether or not it will work in most cases.
    So basically, what I want to know is will I be able to run an LCD panel (I'm looking at one of DennisK's atm for eg) from a 50pin connection (bearing in mind I'm not afraid of a little hacking/soldering).
    Pro web developer looking to take on a web site for free.
    Get in touch if you're interested in having some work done.
    Nobody? Not even a hint?
      pleeeeeeeeez
        I would think it should work.... if you get the pinouts, and make a custom cable. The 31 pin hirose plugs can b a bit of a ***** to solder, but i managed it on my 2nd attempt (order more than 1 connector).
        My Setup
