Xenarc Touchsreen software
  • Xenarc Touchsreen software
    I wonder if there is any other alternative touchscreen interation software other than the one Xenarc supply...
    Im getting some issue whit winamp. If i move the volume slider, then i must click on the Winamp windows to remove the focus from the slider. If i dont do this, if I click anywhere else on the screen, it move the slider to 0% or 100%(depending if i click right or left of the winamp windows). This can be very dangerous when driving high power amplifiers...
    Also, it would be cool to have the right click done when you hold the click 2sec. It work like this on the pocketpc we have at work and this is very usefull.
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
    search teh forums for EGALAX
    How about the Wiki?
      How, fast answer, thanks!
      Ill try this tonight. So i understand that Xenarc use this controler....
      Link for everyone...
      eGalax_eMPIA Technology Inc. ---- Video IC & Touch Panel Solution ----
      ED Nine.2x
      ED Nine.4
      ED Nine.1
      ED 110v.2 (x2)
        On my xenarc it does right click if i press and hold?
        10 acura TL tech
        10 BMW S1000RR
          You need to check advance settings for the right click option to disable it (if is no in advance you need to update your soft)
          Thanatos.
          RexBruMet Skin for FrodoPlayer
          Nissan Aux-in MOD
          Originally posted by bgoodman
          We're an international forum, post in whatever langauge you like.
            yeah, I have right click and like thanatos said, in the advanced options, you can find a lot of nice options for it
              Thx guys, the right click work like I expected!
              But do you have the same issue whit winamp or other soft? It's still the same for me.
              ED Nine.2x
              ED Nine.4
              ED Nine.1
              ED 110v.2 (x2)
                not for me... if I play w/ the sound in Winamp, as soon as let go of that slider for the volume it releases it and it's all fine... so hopefully you get it working too
                  What is you config? Normal mode? Winamp 5.3 ?
                  ED Nine.2x
                  ED Nine.4
                  ED Nine.1
                  ED 110v.2 (x2)
                    Um.. yeah, I havent really messed w/ my touch screen config much except that I enlarged the area of the touch screen surface so that's about it
                    as in Winamp.. no, I am using RR so they suggest to use the older 2.9 version
                      Anyone know how i could fix that issue? Or this is a bug whit winamp and how the touchscreen software work?
                      ED Nine.2x
                      ED Nine.4
                      ED Nine.1
                      ED 110v.2 (x2)
