NEWBIE...Is this monitor good???!!!!
  • NEWBIE...Is this monitor good???!!!!
    hello there, ive been into carputing ever since ive seen this forum, however, im a newbue so i need some help, i own a mazda 3 n the only cheap option which i s kinda similat to the oem setup is this screen :
    Auto Flip Screen (When signal is detected)
    - 6.5" TFT screen (16:9)
    - 1200 x 234 dots
    - Adjustable angle (Up / Down / Left / Right)
    - Brightness 350 cd/m2
    - 1 CCD input for your reverse camera
    - 1 RGB input for your navigation system
    - Size 314 x 335 x 91 mm
    - Comes with a remote
    so i need ur opnion concerning this screen, whether its good or not, and wuts the diffrence between it n a vga screen..n can i use it as a vga screen or not..!!!!!
    How about a link or at least a brand?
    Is it an ebay deal?
    You really haven't provided enough technical info to give you a useful response.
    A VGA "screen" has a VGA input for the computer. Same as your desktop. You really want a touch screen model if you plan to use it in car for carputing. Every other input is ultimately a big PITA.
    And, please try to use spell check or type the full word out. That "texting style" is pretty hard to read. If people don't want to read your posts, then you're not going to get many answers.
    Cheers
    BJ
      A VGA screen has a VGA input. If this screen doesn't have a VGA input, how would you use it as a VGA screen?
      How about the Wiki?
        - 1200 x 234 dots
        From the above 3 lines.
        1st line: Will be ****ty for computer display PERIOD.
        2nd line: Good to have reverse cam, but that is totally optional.
        3rd line: RGB input What exactly does that mean. If it is really a RGB with VSync and/or HSync, it can be use the same way as the PSOne screen.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
