I need some major help asap pleeeeassseee
  • I need some major help asap pleeeeassseee
    So i bought an indash motorized VGA touchscreen and im trying to install it. There are four wires. Yellow, black, green, and red. However this is how they describe installation...
    In the Picture it says::
    Yellow to + battery terminal
    Black to - battery terminal
    Green line to ground
    Red line to lighting swtich
    In words they tell you ::
    Black line is connected with GND
    Red line is connected with Control switch for lighting
    Green line is connect with control for backing or GND
    Yellow line is connect with + battery
    sooo........this is what I did. instead of running wires out to the battery and such....
    Yellow wire to yellow wire on radio harness(12v supply terminal)
    Red wire to orange/white wire on radio harness(lighting switch terminal)
    What do I do with the green and black wire i've tried a million differnt things..
    black to neg battery green grounded and vice versa
    black grounded and green loose and vice versa
    black and green grounded
    but no matter what i do the clock on the thing works but thats it, it wont turn on and the screen wont flip out...any ideas?
    did you turn your key on before you tried to turn the in dash monitor on?
      yea i turn on the car and try to turn it on but nothing. when i plug in the harness all the lights come on for like 2 seconds then shut off, the clock still runs, but it wont power on
        For testing purposes I would run a power wire from the battery and connect both black and green to battery. Then I would test that the wire you are using for switched power really is switched. If you get that working then you can switch one wired at a time to something closer to the monitor and see if it still works.
        My Work Thread:
        http://www.mp3car.com/vbulletin/showthread.php?t=72552
        Source switcher for Lill
        http://www.mp3car.com/vbulletin/show...d=1#post841007
          i tried hooking both black and green to neg. battery terminal with no luck
          i dont even understand the purpose of the lighting switch line...is it neccessary? could that be my problem?
            Did you check the fuse? Do you have a model name and number or a pdf of the manual?
              here's the manual http://www.filoniki.com/vgatouchmanual.pdf
                Presumably the Red line causes a diming of the backlight when your headlights are on.
                More likely it just dims the other lights on the monitor though (not the backlight of the LCD).
                My Work Thread:
                  the fuse is fine
                    Black is your real ground. I think the green wire acts as a source switcher. Swithcing to composite when it is high. Hence, tie it to grn when you are not using that function.
                    My Work Thread:
                      Baking? You can cook things with this :s I think the guy who wrote that was baked
                      Maybe the green wire is the turn-on wire ( the IGNition wire ( red usually )
                        Could be. Or it could come on with a VGA signal.
                        If it were mine I would try it though. I doubt pushing the green hot would blow anything.
                        My Work Thread:
                          whoever wrote it up is retarded but in my manual it says control for backing
                          so i should tie green and black together and ground it?
                            Its not nessasary. It can float and not cause problems.
                            My Work Thread:
                              ok well i just ran out and tied green and black together along with the ground wire and still nothing.
