4-5 inch LCD screens?
  • 4-5 inch LCD screens?
    Hello All,
    I have been looking for a 4 ( to max 5 inch ) LCD screen. I looked around the min i could find was 7'. Or if I find small ones they are either made for DVD player but dont' have the proper connector plugin (VGA for PC use).
    Do you know any brand that makes these type of LCP ( like lilliput but for much smaller sizes between 4 and 5 inch).
    On the dash board I have the speedometer and the RPM meter. I want to remove the RPM one and put a tiny LCD there instead. I bought OBD II reader from ebay ... so you can see where this is going.
    I dont need it to be touchscreen ( just pointless).
    Any help will be apretiated it!
    Thanks.
    Mod a PSOne screen.
    The controller boad is a little bigger than 5" (4x3) format.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      im using a Boss 5.6" the quality is EXCELENT.
        i duno if this might help... not sure wat its called... but the one side plugs into ur compu "tv" out and so the other side plugs into ur screen "the yellow tv in"
          So, using the PSone screen with the VGA connection a good choice for this? I am working on doing the exact same thing......
