9pin mini din or VGA/USB extension.
  • 9pin mini din or VGA/USB extension.
    Which is a better option? 9 pn mini din extension from your trunk to front of the car to connect the lilliput LCD or using two seperate extension cables, one USB and one VGA. Any information will be helpful.
    FULL CAR PC. START TO FINISH IN ONLY 3 WEEKS
    You have to make a call on this one yourself.
    Normally, I would do like this.
    - If I'll plug the TS and other devices to the hub up front, I will run a vga and usb.
    - If there is no other usb to be used up front, run a mini din
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      Thanks. I think I will use a usb and vga cable, cause i will have a cd drive in my glove box.
