Fitting touchscreen in Peugeot 207
  • Fitting touchscreen in Peugeot 207
    Goodevening,
    I've recently bought a Peugeot 207, and as computers are a great hobby of mine (and my after-school job), I want one installed in my car.
    The centreconsole looks like this:
    http://img263.imageshack.us/my.php?image=brest04rm6.jpg
    My question is, whether I will be able to install a 7" lilliput monitor, if I remove the radio and storage room?
    I want to create my own bezel (unless one exists already?), so that the install will look more or less OEM (thus I do not want an indash touchscreen).
    The slots are standard 1DIN's.
    If I were to create a bezel myself, how would I make it removeable again?
    Best regards
    Kenneth
    Denmark
    It looks like this with the radio removed:
    http://img291.imageshack.us/img291/153/img0932gt5.jpg
      It is very easy on your part. You will remove the stock HU, and the empty drawer there (storage), and voila: enough place to have a double DIN unit. Wich is exact size of a 7" display...
      My second Subaru skin
      Full screenshots second skin
      My car photos
      CarPC Progress
      ■■■■■■■ - 75%
        You could that, which is probably the best idea...or you could see if the factory nav system uses a 7" monitor. If so, buy your self the bezel, and replace the factory central information display you have at the moment.
        Renault Megane...the OEM look
          I've considered both options actually. I like the first one better, as I am worried that the latter will put the screen too far away for comfortable (read: safe) use while driving
          My concern with the first option is, how I should mount the monitor?
          It would need a bezel, which I can remove again like an ordinary DIN-radio. Any good ideas for this?
          Thanks for your answers so far
            I did so.. I bought a secondary bezel and got it slaughtered.
            You can see the story here: http://www.mp3car.com/vbulletin/fabr...r-install.html
            What i am trying to say is that if you buy a replacement bezel to play with, you risk almost nothing, just some work... I preffered to have the monitor disasambled, and i have fixed the TFT touchscreen inside my modified bezel, using the same mounts i found inside the original case of the display.
            My car photos
            CarPC Progress
            ■■■■■■■ - 75%
              I'm not quite sure that'll be of any help to me. I can't seem to remove the vertical sides around the radio (the carbon ones), which I think would be comparable to what you did in your Forester.
              I would need something like the holes found in the sides of the original radio, to be able to unmount the display.
                I am sorry, but i don't you have to remove anything... you can leave your carbon trims there...
                You just have to create a "housing" that should hold your screen. When you don't want it anymore, you simply remove the scren ansamble and re-install your radio and storage compartment.
                You can check the mp3car store because they are selling some "double din bolt in kit" like this: http://store.mp3car.com/Subaru_WRX_b..._p/dsh-012.htm
                My car photos
                CarPC Progress
                ■■■■■■■ - 75%
                  I'm sorry if I'm slow, but I'm not that familiar with the different mountingsystems for car stereos.
                  If I create a housing, I'd need some way to be able to remove it again, once it has been "plugged in", like the standard radio has with the four holes. The storage cabinet beneath it in the pictures can be removed by prying it out with a flat screwdriver, but I'm not sure this system would be good, for a bezel with a touchscreen in it.
                    Sure not.
                    But When you will remove the radio also, you will find the fixing you need for your screen housing. I wish i had your type of bezel in my car...would have been not more than one day to make a fit for a display there...
                    My car photos
                    CarPC Progress
                    ■■■■■■■ - 75%
                      Cool - I've just looked at an old car radio I've got, which also uses the four holes to pry it out - looks like I should be able to use those, if the width of the screen will allow me to have them in the bezel. How wide is the panel of a 7" screen?
                        No idea... i use an 8.4" screen...but i can guarantee will fit with no problem the width of the DIN standard wich you have...
                        My car photos
                        CarPC Progress
                        ■■■■■■■ - 75%
                          Alright. I think I'll get a Xenarc 700TS and work on it from there
                          Thanks for your help.
                            Good luck, and post pictures when done.
                            My car photos
                            CarPC Progress
                            ■■■■■■■ - 75%
                              Pug 207 project
                              Just in case anyone is interested to look at fully finished CarPC in 207
                              Once I got an idea to buld the CarPC in my Peugeot 207 I looked at this topic as well.
                              Here you can see the result of my installation:
                              translated version of project description (via Google)
                              http://translate.google.ru/translate...12782%23912782
                              original post (in Russian)
                              http://forum.aves.su/viewtopic.php?p=912782#912782
