Lilliput Touchscreen Inverted
  • Lilliput Touchscreen Inverted
    After installing my touchscreen drivers for my 7" Lilliput widescreen, the touchscreen options seem to be inverted. If I touch the bottom right it ends up at the top left. I tried calibrating it but it keeps saying I failed. Any solutions?
    In another thread I think someone said to make sure that you hold your finger in place during calibration. Not 100% sure though...
      Use the Stylus
      on my screen, calibration also continuously failed when i used my finger. what you want to do is take the stylus and hold it in the dead center of the flashing x until it becomes solid green. Then move on to the next X until you are calibrated. If that fails, try searching for updated drivers. And if that fails, i'd say you have a bad screen and/or usb not getting enough power.
        had the same problem, I unistalled the drivers, deleted the folders and installed it again..it still kept doing it so I click on advanced on the calibration. software..and there is a grid like calibration....click around you will find it..it fixed mine
          Inverse Touchscreen on Lilliput EBY701
          Hi guys,
          Tried searching around but to no avail and that's why I have to ask the following question.
          I have just got a lilliput EBY 701 and the VGA is screen is working well on 800 x 600. However, as I am currently using Window Vista Home Basic, the package did not come with any driver for Vista for the touchkit. I did a search from MP3car and downloaded it from http://www.eeti.com.tw/web20/eg/drivers.htm (the Vista version).
          Upon installation, I realised that the cursor will move to opposite end (both vertically and horizontally). I tried to find touchkit in the Program folder but it is not there and therefore I could not carry out any callibration.
          I would like to seek advice from the forumers here on the approach to resolve the above issue. Thanks in advance.
          Rgds
          Mike
            Touch kit may have not made a proper link entry. When you click start in the search box type touch and see if anything come up. If not, I'll install it on my vista computer and let you know where it goes.
              Thanks. I have managed to solve the problem.
                I am having this problem too. the cursor is inverted. i was wondering where do you find the configuration screen where you can calibrate the touchscreen? thanks.
                EDIT: I have found the drivers that i have been searching for quite awhile for. never mind.
