how to remove scratches on a lcd
  • how to remove scratches on a lcd
    Anyone know if it is possible to get scratches out of a soft touch tft monitor. Been doing a install in the car and court the screen with some sand paper.
    http://img.photobucket.com/albums/v2...yandsupra1.jpg
    If you switch the touchpanel with a new one, the scratches will go away.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
      yea but than means takin it apart, scary for me as i am a builder not a pc expert. Where would i even get one. It is a liliput 7".
        digitalww, ebay, or the mp3car store for a short list.
        And it is really easy to replace. Look at some threads about how to take apart the monitor. It is really easy but be careful of the ribbon cables in the ZIP sockets.
        1.9in x 2.9in -- 47mm x 73mm
          haha
          2005 Ford Mustang GT <- - - UPDATED PICTURES
          2003 KAWASAKI Z1000 - CUSTOM MODZ
          MBK (AIM = IllMBKllI)
            the panel should of been out of the bezel before you started fabricating it.
            Continued Worklog... Upgrades in progress:
            *15.4" WXGA LED backlight touchscreen upgrade
            *Custom fiberglass dash bezel
              You can sometimes get a fluid on ebay which is supposed to take away light scratches. Might be worth a try, unless you have gouged out a chunk of the monitor!!
              Just search for scratch repair on ebay!
                Something like Displex might help - I've seen it used for mobile phone displays, but it is an abrasive polishing compound, so I don't know if it will cause more of a problem on the touchscreen - ie it might improve the appearance, but might cause degradation of the touchscreen facility.
                  Finaly someone trying to help rather than tell me i should have done this or that.
                  Thanks for that.
                    Thanks for that.
                    Remember kids down the middle not across the street...
                      I tried displex it made it worse. It basically discolors the that part of the touch panel so it looks like there is a haze. Any one try anything else that they had luck with?
                        You can probably use a polish to remove the haze. I'm not sure which kind, though
                          you can polish an LCD... it's just plastic... bear in mind though that you'll likely abrade away any anti-glare coating that's on there... so plan to replace it or have the high-gloss glare machine of death.
                            I just ordered the lilliput touch panel. Hopefully it will work for a tview.
                              Forget it, to polish it like that, you have to take it apart, which means you might as well get the touchscreen part, and make it easier on yourself!
