Nec 5,5 Screen?
  • Nec 5,5 Screen?
    Hi all.
    I've got this nice NTSC/PAL 5,5 lcd,which have input for comp video. But I've found out that there's a circuit board inside, that converts the video signal back to R/G/B and Horisontal and vertical sync. I was thinking of connecting the VGA signal directly to the screen instead, do any of you think this is possible ?
    I would ofcourse se to, that the refresh rates coresponded to the TV standards. Could it be fatal for the screen if the refresh, was'nt the TV standard ?
    Hope that this make sense to somebody.
    Regds
    There's somthing rotten in the state of Denmark.
    Finished IIIIIIIIIIIIIIIIIIIII 99,5%
    M10000, 256mb, 20gb 2,5" drive, 7" vga touchscreen.
    ALL monitors need RGB and H and V sync to operate, regardless of whether it is a $99 special at Kmart to the latest HDTV. But in your case their is still the issue of interlacing. Even if you set the video card out to "match" (something I have little experience with, admittedly) PAL or NTSC, your computer would still be outputting a progressive signal, while the monitor would need an interlaced signal.
    So is it possible? Sure, but it may not be feasible.
    KG6OQD
    www.americansandassociation.org
