Looking for a replacement 4-wire touch screen controller board
  • Looking for a replacement 4-wire touch screen controller board
    I am looking for one, are there online vendors where I can order this?
    It is for my lilliput 7 inch touch screen.
    Are you looking for the actual controller (USB to 4wire resistive touch), or the overlay (the big glass panel)?
    Both can be had from Armen or Motorcity. They are around $50 each.
    1.9in x 2.9in -- 47mm x 73mm
      looking for the actual controller.
      Are these things all the same? I typed 4 wire resistive touch controller and a bunch came up. I contacted motorcity also.
        Yup pretty much. Some are 4 wire, and some are 5 wire. That and the interface method (db9 or usb) are pretty much the only differences.
          When I killed the controller on my 629, I got one here: http://shop-on-line.tvielectronics.c...ch-controllers
          It worked perfectly.
          Gen 1: Pentium 3 1GHz - ATX - 2005
          Gen 2: Pentium M 1.6GHz - ITX - 2006
          Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
          Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
          ...it never ends
            Thanks Psyrex,
            Ended up ordering it from xenarc before seeing your post.
            Did you grow up in Oakland?
