Any results from using a VGA duplicator/booster?
  • Any results from using a VGA duplicator/booster?
    As soon as I added the VGA extension cable to my carpc the quality on the screen took a nose dive. I've gotten used to it, but I know it can be better.
    There is an ATEN VS92A VGA signal booster for $30 on eBay (Buy It Now). I am wondering if this would be sufficient to reduce the signal loss I get?
    They also have Belkin OmniView extenders for around $20. Seems like a cheap deal. There are a few that carry over cat5 as well (two units).
    That happens when you get crappy VGA cables. Basically, you get what you pay for. You're probably better off getting a high-dollar cable from a place like a network or audio supply place.
    Progress:
    [■■■■■■■■] 100%
    Mitsubishi 3000GT car computer
    Previous budget Honda carputer
      Yeah I got pretty cheap cables. What's the going rate for good VGA cables?
        i bought mine from a local computer store i work at... look for ones with good shielding, the only problem is that there so thick they are hard to bend and hide.
        here is a website that seems to have the same one I have
        http://www.vga-cables.net/premium-vga-cables-list.html
          before you buy more ****,
          are you sure that maybe just one of your vga cables is cheap and not shielded enough?
          maybe try a different VGA extension.
          I extended mine and don't have any noticeable drop.
            wha'ts funny is that the high quality vga extension was cheap at cirquit city, but the usb extensions are expensive as fuc*
              You should pay upwards of $20-30 for a good 6' VGA cable. Likely your problems will disappear when you do that.
              Why are USB cables so expensive?? Because printers sell dirt cheap, and do not include a USB cable.... So you buy their $30 cable seperately so they makeup the loss on their printer.
              Progress:
              [■■■■■■■■] 100%
                That's actually the problem I think. I bought a cheap eBay cable for around $20 (25ft). It's fairly thick, much thicker than the one that came with the screen. It works great for a CRT monitor, but when it comes to VGA on an LCD, quality deteriorates right away.
                I also have extra slack, much more than I needed. I'll try getting a shorter cable of higher quality.
