LCD rear view mirror.
  • LCD rear view mirror.
    I am debating whether or not to use the carputer's LCD monitor as the rear view, or instead to use a rear view LCD mirror. Check them out here:
    Main goal here is aesthetics. If I go with the rear view mirror/monitor, I would want to engineer a button on the mirror to activate recording in the event I want to record where I am driving, etc (one touch recording).
    Which one should I go with?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for
    - Facilitate HVAC control.
    aesthetically speaking the mirror would serve a fool proof way of functionality
    if the lcd fails the mirror still works
    your going to be using an rca cam i see so you will also need to think about what sort of capture device you will capture the rca feed with. the carputers lcd might be easier in that it will simply already have a button, which is the touch screen obviously.
    | '_ |__\___
    [(o)|___(o)] XB
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
