Gamma adjustment for night, very low brightness desired
  • Gamma adjustment for night, very low brightness desired
    Hi,
    I have a Lilliput 8" Wide Model 889GL-80NP/C/T, using RR and it's built in gamma control.
    At night, the brightness of the screen is still too high.
    It is not secure. People from other cars or pedestrians can notice the screen very easily at night.
    So, what settings are you using in your gamma configuration? Or what else are you configuring or doing to reduce screen brightness at night?
    PS: At day normal or high brightness is important.
    Thank you
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
    Same monitor - same problem.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      http://www.mp3car.com/vbulletin/road...ml#post1144686
      OLD SYSTEM (DEAD)
      M2-ATX Power Supply
      Windows XP SP3
        Thanks!
        \/ |_ /\ [)
        1995 Civic Sedan EX
          Setting gamma does not reduce the backlight brightness, just the transparency of the TFT panel.
          For reducing the backlight, wire a condenser (2.2kV, 22-33pF) serial into the backlight high voltage wire. At day, you have to short condenser pins for normal brightness with a switch.
          Be careful about the high voltage shock risk, insulate the components as well as possible!
          If you are handy, apply some white leds around the backlight unit from sideway and switch the normal backlight off. It needs a voltage approx 0V at a certain pin of the backlight unit - switch this point without any risk, because it is low voltage.
          Alopecia perniciosa
