Xenarc 700IDT (700-IDT) Power Pinouts
  • Xenarc 700IDT (700-IDT) Power Pinouts
    I searched forever trying to find this information. Couldn't find it here, so ended up calling Xenarc to get the information. Figured I'd post it here for future searches:
    Here are the power connections for the 4-pin molex header on the back of the 700IDT (pinout is the header on the board, not the cable):
    (and in case that IMG goes red-x, a crude ascii version: )
    __=__
    |4|3|
    |2|1|
    Pin 1: GND
    Pin 2: ACC
    Pin 3: NC (no connect)
    Pin 4: +12V (constant)
    Note, that this is not the same configuration as the 4-pin cable on an ATX power supply. Pin-2 on that cable is GND so the monitor will not turn on. Fortunately Pin 3 is NC so you won't fry anything by accidentally plugging in +12V there.
    Also, if you want to use the co-axial power plug to the right of the 4-pin header, you need to short Pins 2 and 4 together so that the ACC pin is powered.
    Hopefully this helps some people out. It certainly would have saved me a couple hrs of searching. (I kept at it while waiting for Xenarc support to open 45 mins late. :P )
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
    Just realized there was a sticky in the forum (everything about xenarc). I copied/pasted this info into that thread. Mods, feel free to lock/delete this thread.
    Thanks!
