I have a double-din spot is a &" monitor the largest I could fit?
  • I have a double-din spot is a &" monitor the largest I could fit?
    I mean on monitors such as lilliput people often take off the bezel or cut it correct? AND I also have probably about 1 centimeter on each side of my CARS bezel I could cut. Do you think I could fit an 8 inch?
    You mean *" ?
    Laidback
    The ultimate CarPC - Wow!
      I just got a chevrolet Colorado and Im thinking of doing the same thing. I would have to do some modifications behind the dash to fit the 8" but it would look far more stock than putting a 7 since it would take up the perfect ammount of space. A double dim opening is approximately 7"x4" and thats the approximatly the size of the 889GL-80NP/C/T
      lilliput display. therefore the custom cover would be unnoticable
