Shark 8" problem
  • Shark 8" problem
    i HAVE THE SAME PROBLEM My 8 inch shark screen from gooddeals18. Yesterday the screen just went black while rr was running. The wierd part is that the touchscreen part of it still works. I push where play would be on the screen and the computer responds, next, pause etc etc.
    Shark 8" problem
        It is not weird, because that unit is TOTALLY INDEPENDENT, not the part of your monitor (it is just ON the monitor). That is a USB-powered flat mouse
        Alopecia perniciosa
          so how i can solve the backlight problem?
            As the previous poster said (I do not know which topic, because you have invaded all topics with your problem), it can be a connection problem.
            Disassemble it, pull out all connectors, wipe and rub with alcohol, push back them.
            Regarding the type of the problem, it is possible that the disassembly-assembly could help alone.
            If not, follow my advices in other topic (with the original question).
            Alopecia perniciosa
