Looking for good a 8" touchscreen
  • Looking for good a 8" touchscreen
    I'm looking for a good 8" touchscreen.
    This size is the max that fits in my car.
    What is a good 8" screen right now on the market?
    I prefer a widescreen, but it's not a must.
    In the shop I see a
    Lilliput 8" Widescreen VGA Touchscreen 889GL-80NP
    But when I read the reactions here for this screen.. they are not really good
    I have also an eye on the VM84 8.4in TFT-LCD
    What other 8 inches are there on the market that are good?
    And maybe a stupid question.... but how do you guys turn the screen on,
    and acces the settings of the screen when you build the screen in the dash ??
    Like this one..
    Ok... forget above!!
    The whole day I've looked on different websites for touchscreens hehe.
    There are 2 screens that I have chosen:
    Xenarc 840TSV
    * For In-Car Computing, PC, Server, GPS, POS, and various VGA Use
    * 4-wire resistive Touch Screen (USB)
    * Multi-Monitor Touchscreen Support
    * VGA Input (15 pin D-SUB) x 1 & Video Input x 2
    * Audio Input x 3 / Built-in Speaker
    * NTSC / PAL Multi-System
    * 4x3 Aspect Ratio
    * High Resolution Display - up to 1024 x 768
    * High-Brightness CCFL
    * High Performance Image and Video Signal Processor
    * Auto power-on upon signal detection
    * Automatic display adjustment
    * On Screen Display Control
    * Desktop Stand: 360 / Height Adjustment
    * VESA 75mm mounting holes
    * 26-Pin heavy-duty connector
    * Anti Glare Coating
    * Supports 11V DC ~ 24V DC
    And 2...
    CTF840 - VGA 8.4" TFT - Touchscreen USB
    LCD Size 8.4" Aspect Ratio 4:3
    VGA Resolutions 640x480-1024x768 Physikal resolution 800x600
    Dot resolution 2400x600 Brightness 400
    VGA Input D-SUB 15 Video Input 3x PAL/NTSC (RCA)
    Audio Input 2x RCA (Stereo) Touchscreen USB
    Case color black Power Input 12-24VDC
    Power Consumption 10W Case size 232 x 162 x 36 mm
    Visible area 171 x 130 mm Certificates CE
    Weight 650 Bauform On-Dash
    Warranty months 24
    So these 2 are the ones I maybe want to buy.
    I want some reactions from you what screen is the better one of these.
    Please give me some advice.
    I'm getting crazy now
      I have a lilliput 889gl and I like it.
        Yes.. but my choise is fallen on these two
        The liliput connector is not very friendly... it's build a bit crappy I think.
        Please some more replys??
          I'd suggest running a search on here for those model numbers and see what people's experiences are.
          Not everyone has experience with every product on the market.
          Jan Bennett
            I'm going to buy the 10.4 inch from the topic above
