2004 oem navigation display
  • 2004 oem navigation display
    Hello to all,
    I am extremely new to this technology all together, but I love it. I appologize for being off topic, however reading many post's it seems alot of people here know what they are talking about.
    My question is this. I recently bought a 2004 accord and i noticed that the dislplay seems to be recieving some interference, kinda like back in the day when a vacuum/microwave was on the television would go wavy. Its kinda like that, it isnt "that" noticable and Iv found that it ONLY does it when the key is NOT in limbo mode. When the key is in limbo mode the display is solid with no wavelike effects at all, and when the key is clicked foward or engine running the display acts a little weird and has that wavelike or liquid swim look to it "just a little". Its not alot.
    Someone thought it may be that my eyes are sharp enough to see that this refresh rate of this LCD screen is like 15 fps and i might be able to just see it happening but i dont think so because like i said it doesnt happen in limbo mode.
    Anyone got any ideas of what might cause this? Is it any frequency's or something that might be interfering with the screen and causing this slight distortion???? Any ideas will be extremly helpfull.
    Thank you very much.
    Since it happens when the engine is running but doesn't when stopped, I'd suspect either the alternator of supplying some kind of interference of some sort of aftermarket devices such as car audio or GPS unit.
    Do you have any aftermarket devices in the car? If so, disconnect them and see if you get the interference.
    Want to:
      2004 oem Navigation Display(2)
      ----Aftermarket parts, hmmm ---- Not that I am aware of. There may be some aftermarket parts under the hood somewhere ie alternator or something, but as far as electronics I do not see anything aftermarket. OH! actually there is one thing. The dealership had this circular disc shape thing with a suction cup that they forgot to remove from the vehicle when I bought it. I believe it is used for tracking if someone stole the car on a test drive. Im gona take it out of the car to see if that possibly had anything to do with the interference.
      Thanks for your input very much, aftermarket parts sounds like a very good explanation.
        2004 oem Navigation Display(3)
        Wasnt the disc shapped suction cup thing the dealership left in the console. Maybe the ground wire to the unit doesnt have a secure connection?
          Check it to see, but if it is OEM, they probably would have thought of that.
          You can try wrapping the input cable in aluminum foil to block extraneous RF interference, but that's a long shot.
          It also could be that the screen is going bad.
          Want to:
