lilliput 629gl touch screen problem!
  • lilliput 629gl touch screen problem!
    hi,
    im having one problem with my screen and i have been trying to make work for hours and read forums if i can find the solution. i also tried many of the drivers but still doesnt work! im getting pretty frustrated... if anyone can help or point me to the direction that would be great. its late goodnite.
    And the problem is... ? Just doesn't work? Detected by windows? Driver won't load? Driver loads but TS still doesn't work? Throw some info out there.
    Tidder
    Try RevFE
    I Wish I could ban people
      sorry I wasn't clear what the problem was. the touch screen doesn't work at all. windows does not detect the TS but screen display does work. drivers load and install but still TS still don't work. am I doing something wrong? I will post what drivers I have tried tomorrow my pc is off and im on my pda.
        i used these drivers:
        HIDUsbTouchDigitizer_2.0.0.0525
        All_In_One_2k_XP_Vista_5.0.0.5017
        and this one that came with the box
        Win2000_XP_4.0.2.1929
          These are usb interfaced right? Does the add hardware wizard show up or anything? Have you tried a different computer?
          Tidder
          Try RevFE
            yea I believe so. it does have usb to plug into my computer. no I haven't tried another computer but I will try that today. when I plug the usb in nothing pops up as in install hardware. it usually pop up when I install stuff but not this time
              Any progress?
              Tidder
              Try RevFE
                yup! sorry i took so long to reply been working on my carpc hahah. all i had to do was turn off the screen and turn it back on white the comptuer is on which i didnt do. thanks for your help!
                  Hmm... what a PITA if you have to do that everytime...
                  Tidder
                  Try RevFE
                    I know this topic is super old, but I'm having the EXACT same problem. Windows shows the driver loaded as "USB Touchscreen(Universal)" under Mice and other pointing devices, I've tried all the different drivers I can find, I'm so frustrated. I just want this damn thing to work. SOMEONE HELP!!! please!!!
                    http://img.photobucket.com/albums/v601/zoned019/sig.jpg
                      Im having same problem. anyone have a fix? TS wont even show up in System profiler in os x. Im going to check the continuity of the 4 wire ribbon cable that connects the TS to the main board. i rekon its fracked
                        well its not the ribbon cable, iv tried a few diff SKS and 9pin Din cables also. i dunno what it is...
                          the ribbon cable coming from the touch panel might be installed backwards into the controller board. When I first installed my touch screen, the computer wouldn't recognize when i touched the screen until I reversed the skinny orange looking ribbon cable.
                          carputers
