Lilliput 629 Barrel connector
  • Lilliput 629 Barrel connector
    I wanted to find out if anyone can confirm if the barrel plug on the AV connector is in fact for 12V power? I didn't get a manual with mine, so want to find out.
    Gennerally these connectors are, but I don't want to try it out and regret it 10 seconds later (which usually happens!)
    Also, is anyone using this for powering their LCD? It seams like most people are plugging in the barrel plug directly into the side of the LCD, or am I mistaken?
    Barrel plug is the second from the bottom... right below the yellow RCA
    Hmmm... I take it from the lack of replies that no one is using this barrel connector? Too bad it's next to impossible to find lilliput technical information on the web anywhere.. and in english <g>
      I've got the manual, ill check it out and get back to you as its in the garage
      New Car PC Build list in progress
        OK according to the manual the "Black Jack" is DC 12V power input (the inner is + and the outer is -)
        Hope this helps
          it's the power input
            Excellent, thank you both. Figured as much, but didn't want to chance it and end up causing problems with my display
