Lilliput Touchscreen USB connector
  • Lilliput Touchscreen USB connector
    My generic LCD touchscreen cracked. I found a replacement that is nearly the same size. It is the touchscreen for the Lilliput 809GL. I need to know if the ribbon connector will fit with my current USB controller.
    If you have pictures of the lilliput touchscreen connector or USB controller input please post.
    I have a lilliput 889GL with the LCD panel out. I can take pics of those connectors, but I don't know if they are the same as the 809 or not.
    From what I see, it just looks like different aspect ratios. I would think the wiring should be similar.
      thanks. greatly appreciated. ill assume that all lilliput connectors are the same.
        Hope this helps:
