How to set 800x480 under Windows XP
  • How to set 800x480 under Windows XP
    I've just set up my Xenarc LCD and it works fine running at 640x480. However I can find no way of setting the screen resolution to 800x480. The only 800x option is 800x600. I've tried this on 4 PCs and tried powerstip to no avail.
    I'm I missing something stupid.
    Many thanks
    Chris
    I cant figure out either..
    could somebody please help?
    I'we tried powerstrip.. made a custom setting ... then the powerstrip want's to restart, do update the system, or make sure the computer "likes" the resolution... .
    no luck.. are we missing something obvious?
    Graphic card in Carputer : Gforce4 mx420 PCI
    Graphic card in Desktop Computer: Gforce3 Ti500
    Richard
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
      after the machine restarts, the resolution does not automatically change....you have to change it manually to get your resolution. I have only messed with it for a few minutes but it worked.
      good luck
      DigitalDub
      1200 mhz duron/ 384m pc133/ 6.4 gig for OS / 75 gig storage/ 32 meg Nvidia Geforce2 wit TV out / onboard sound / GPRS / 7" digitallww flip out / X10 Mouseremote / 255w inverter (temp)
      Audio
      Nakamichi CD-45Z HU / Monsoon amp and 8 speakers
        A problem I maybe have is that wherever I've install powerstrip the custom resolution button is greyed out.
        Anyone know why this is. Everything would suggest that all features are enabled durring the evaluation period.
        Chris
          What i did was rightclick on the taskbar icon, go to display properties and configure. I have the hide resolutions not supported by monitor unchecked. Then click on advance timing options, uncheck the lock total geometry and resolutions, and i have realtime adjustment checked. Then just go and add the custom resolution.
          Progress here: http://www.siriuscybernetics.net
            Right click desktop
            Display properties>settings>advance>adapter>list all modes...
            It gives you listing of all display resolutions your card can support.
            - 3+ years & still no carputer!
            - Done collecting parts
            - Currently planning setup
              If you have and FV24 board, you can check out this thread.
              http://www.mp3car.com/vbulletin/show...threadid=11717
              NEW complete and updated My project with 100+ pics on 7-4-03
              If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
                Officially, Microsoft XP will not support anything below 800*600 resolution.
                There are two ways to do it. Hacking a registry or using Powerstrip 3.29 build Build 342 (Full Version). Second choice is safest and it works.
                Hacking registry:
                Go to: HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{23A77BF7-ED96-40EC-AF06-9B1F4867732A}\0000
                On the bottom, you will see:
                DefaultSettings.XResolution 0x00000320 (800)
                DefaultSettings.YResolution 0x00000258 (600)
                Double click values, input any decimal value you want, exit, and reboot the machine. Win XP will display that bubbly thing with a warning saying that you might have a problem with resolution settings. Just ignore it.
                I never used it but people say it works. Just make sure you back up your precious registry!
                Maestro MP3 player: MIS K7T Pro-2A, AMD 1.2GHz, RAM 640MB, 80G HD; Screen: Datalux 10.4 VGA; Head Unit: Kenwood Z727; RF control ON/OFF/RESET
                  i have
                  HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{8B6D7859-A639-4A15-8790-7161976D057A}
                  and
                  HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{DEB8CD67-93DC-4C2C-9005-DAA60194CC71}
                    XP Pro supports lower than 800 x 600 rez fine. I have set my Xenarc to the 800 x 480 rez without a problem, no warning screens etc.
                    After I set powerstrip it is now part of my resolutions set by windows. I constantly change between 1280 x 1024 on my 19 inch monitor to 800 x 480 on my Xenarc.
                    If it is too difficult to set then it must be hardware restraints. I have never tried by hacking in the registry.
                      I used the registry hack to get my res down to 640x480. I am sure that it will work for other resolutions. In fact, i learned about the trick from a thread on this board. Look around for it, it has a good explaination.
                      Also, if there are more than one entries listes, it is reffering to currectly or previously installed displays. Edit both, what the hell.
                      System in the works:
                      Celeron 850 or PIII 933, SB Live! Value into a stock 4 channel amp, ATI vid, 10.4" sharp LCD w/ allen's controller, Elo SW touchscreen overlay and controller, GPS, TV tuner, FW DVD drive, 4 port serial card, and some other stuff....
                      Loads of ideas.
                        1. HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{23A77BF7-ED96-40EC-AF06-9B1F4867732A}\0000
                        2. HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{40DE5AF2-4B48-4F2A-AA93-5FA905996808}\0000\
                        3. KEY_CURRENT_CONFIG\System\CurrentControlSet\Contro l\VIDEO\{4AEF8FA4-78DE-42D6-AFDD-B439569F126E}\0000
                        4. HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{6235E712-3658-4E3E-AC3D-16E6561CAA80}\0000
                        5. HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{F2A0BEA1-C11B-4DB9-B292-490BD242E1FD}\0000
                        When playing with Powerstrip’s Display Profiles, I was able to trace the exact key that makes all adjustments—it was a Key #3. The resolution for other 4 Keys stayed the same, no matter what. Your case might be different. Try and see what happens. However, be very careful! It’s registry.
                        The only sure way to find out which key is performing resolution adjustments is to use a demo version of Powerstrip and see what happens to all keys.
                        In my case, it is Key #3. Your case would be different, I assume.
                          a little off topic but say I get a plasma screen and the max res is 800x480
                          would that look like ****?
                            Plasma screen? As in, home theater?
                            Loads of ideas.
                              yup... a lot of em have either the standard vga input or dvi
