Garbage with Markus' plugin
  • Garbage with Markus' plugin
    I configured it using the onscreen simulation on my home computer which runs XP Pro using the portIO driver. Then, I saved the configuration file for the plugin, and plopped it onto my car system, running 98lite.
    Normally the SA is on the bottom two rows, and the info is on the top two rows. Then, when I press the kee that turns off the SA, it "reveals" more info "beneath" the SA.
    Suddenly, on the carPC, I get all kinds of garbage with the spectrum analyzer enabled. It worked fine on my home PC. The SA now occupies the top 2 rows, except that each row is a mini-SA. So I have two one row high SA's occupying the top two rows of my LCD.
    I have a regular HD44780 40x4 LCD. Any ideas as to what is going on?
    EDIT: I've played with it a bit more, and it seems that when the SA is off, everything that should be on rows 3 and 4 (rows otherwise occupied by the SA) are bumped up to rows one and two, and are "fighting" with the stuff that is normally on rows one and two for space, making everything unreadable.
    Silver 1999 Nissan Pathfinder!
    Completion: [*********-] 90%
    Everything working! Mobile MP3s ROCK!
    LEFT TO DO: Improve power on circuit, fix slow boot time
    - 550mhz PIII on Abit BH6
    - 128MB RAM
    - 40x4 Backlit Character LCD
    - 17 key numeric keypad - Repainted buttons
    - 2.1GB laptop drive for OS
    - 4.3GB drive for MP3s
    http://www.mp3car.com/usersites/bombboyer/ Redesigned, new pics!
    Re: Garbage with Markus' plugin
    I got the same problem using a long lpt cable.
    Rob's boost circuit for the data lines was what it took, it worked flawlessly after that..
    but before, check the wirings.
    schematics at this post
    http://www.mp3car.com/vbulletin/show...&threadid=8664
    My cars
      I am using a 25' cable, but it doesn't work any better with a 6' cable. The only difference I can find with a 25' cable, is that lcdprint.exe will lose a few characters with the longer cable, not garbage, just lose some characters.
      How should I adjust the timings in Markus' plugin to work better with a long cable?
      I want to try that before building that circuit.
      here's a direct link to the circuit: http://www.mp3car.com/usersites/heslop8/lpt.jpg
      - 128MB RAM
        hmm, it was...timing or something. I cant remember, dont got it installed...i tried it and it went into a box, searching for a pc now
        My cars
          I posted a reply to this same thread in another forum, so check for a possible answer about the lines 3 & 4 not displaying.
          Jarrod - Holden VX S!
