Touchscreen has reversed input (x=y)
  • Touchscreen has reversed input (x=y)
    I just bought a 7 inch TFT screen:
    http://www.carmedien.de/stand-einbau...tor-cm132.html
    After installation touchscreen worked, but in reverse way.
    as if the input along the X-axis was put into work along the Y-axis.
    It has the TouchKit driver 4.0.2 with it.
    Does anyone know the solution? I reinstalled several times now.
    no one any idea?
    the problem is that i just fixed it with installing, deleting several drivers. IT WORKED!!
    But I started calibrating (to tweak the input)
    and after that, he erased some things and it was back to normal...which is the bad input.
