EBY-701 button board
  • EBY-701 button board
    Does anyone know where I may be able to get a replacement button board for the EBY-701? I checked digitalww and the mp3car store, neither has it.
    Any chance a 619 or 629 board will work?
    Thanks!
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    Logitech DiNovo Mini
    LSX VOID 3.3
    No one?
    1995 AWD Tsi Talon
    Intel D945GCLF
    M2-ATX
    2GB Corsair
    30GB OCZ SSD
    BU-353
    Lilliput EBY-701
    LSX VOID 3.3
      No one knows? I really need a new button board as I fried my IR sensor section of the board and need to have the IR sensor working. Thanks.
      1995 AWD Tsi Talon
      Intel D945GCLF
      M2-ATX
      2GB Corsair
      30GB OCZ SSD
      BU-353
      Lilliput EBY-701
      LSX VOID 3.3
        Man, you don't need a new board if you just fried this sensor.
        For the record, its next to impossible to fry an IR detector unless you've been modding it and ran it out of specs, but typically they shouldn't die.
        What makes you think its the IR sensor?
        2001 Mustang Convertible Worklog
        Indigo Custom Frontend (Flash/Delphi)
        Blog
        Qube v1.3 Now Available at the mp3Car Store!!!!!!
        The simplest IO controller you'll ever use!
          No, I didn't fry the IR sensor itself... I destroyed the board using a soldering tip that was too big. I actually disconnected the leads in the board. Perhaps some pictures will help:
          1995 AWD Tsi Talon
          Intel D945GCLF
          M2-ATX
          2GB Corsair
          30GB OCZ SSD
          BU-353
          Lilliput EBY-701
          LSX VOID 3.3
            Wow, that's dirty.
            First off, I don't know where you can get one of these button boards.
            With that said, I'd suggest that you hack it up a bit more, what do you have to lose? Buy a smaller tip ANYWHERE and it'll cost you less than the shipping cost of a new board. Then use a knife and cut the traces, etc etc etc. All IR sensors are the same, VCC IR GND (no particular order) so if you can find a vcc point you should be okay...
            Why spend the money?
            Blog
              Yeah, just use a knife and scrape the green stuff off till you see a nice copper spot to solder to for each point. The ground plane above it, the trace on the side, and maybe the 3rd is on top? Just use some solid wire like a resistor lead or glue it down well because if it pulls it will rip the traces off the board.
                I threw my eby701 out the other day, otherwise you could of had it with the extended IR port already
                  I have one PM me and we'll work out the detials
                  My 2007 Scion Tc Install
                    PM sent
                    1995 AWD Tsi Talon
                    Intel D945GCLF
                    M2-ATX
                    2GB Corsair
                    30GB OCZ SSD
                    BU-353
                    Lilliput EBY-701
                    LSX VOID 3.3
                      why would you 'throw out' an EBY701 (or any monitor)??
                      it is worth money even if it doesn't work...
                      F150 Truckputer [1.0] (coming soon!)
                      Fusion Carputer [2.0]
                      Fusion Carputer [1.0]
                        I posted it up for sale for $70 on here and no body wanted it
                        it was no good to me
                        so i threw it
                          $5 > $0...
                          Super duper discount, I woulda sold it for 15 bucks before I just tossed it. Shame.
                          Blog
                            did you find a button board? i have an extra 5$ plus shipping
                              PM sent.
                              1995 AWD Tsi Talon
                              Intel D945GCLF
                              M2-ATX
                              2GB Corsair
                              30GB OCZ SSD
                              BU-353
                              Lilliput EBY-701
                              LSX VOID 3.3
