HELP!!! Lilliput 889GL-80NP "No Input Signal"
  • HELP!!! Lilliput 889GL-80NP "No Input Signal"
    I have looked all over the board to try and find a solution to my problem. Screen worked fine until I removed the PC from the car for some troubleshooting. Now I can't get a vga signal. A/V cables work fine and PC works fine hooked up to inside monitor. I really need some help with this. Also if i hook it up to my desktop, it works. Have tried two different mini-itx boards with no signal.
    So the problem must be with your screen.
    Probably not auto selecting the picture source. Maybe redo the trick where you get it to auto-on on a signal (the numbers on remote)
    or just generally check it works in any way, take it out of the car and bench test it.
    MX-5 Carputer Progress:
    (Check ibfragalot's Worklog)
    Purchase [****_] 95%
    Design [*****] 100%
    Install [*****] 95%
