HAMI 8" Touchscreen monitor
  • HAMI 8" Touchscreen monitor
    Can anyone help me, I have misplaced my vga lead and need the pinouts for the lead, one end has an 8 pin mini DIN plug and the other end is the standard 15 pin VGA connector.
    I have tried so many combinations so the only way is to actually test the lead with an ohmmeter wire for wire.
    Not sure what you need. This might help.
    Want to:
      He needs the VGA cable pinout for his specific monitor.
      The VGA goes into an 8-pin connector, then into the screen.
      If you're willing to take the screen apart and check out that connector you could probably figure it all out much easier... wires are typically in numerical order so just use a multimeter to figure out which colour wire goes where and then try connecting pins to it.
      2001 Mustang Convertible Worklog
      Indigo Custom Frontend (Flash/Delphi)
      Blog
      Qube v1.3 Now Available at the mp3Car Store!!!!!!
      The simplest IO controller you'll ever use!
        Thanks for that but I needed the specific pinouts for the HAMI 8" Touch Screen Monitor (model 8001) 8pin MINI DIN plug.
        Thanks anyway
          I thought of that but its under warranty and it has a seal.
            hami vga pinout
            here is the cable pinout:
            8 pin Male 15 pin MALE
            mini-din VGA
            1 Hsync 13
            2 R Video 1
            3 Vsync 14
            4 I2C data 12
            5 I2C clock 15
            6 G video 2
            7 GND 5,6,7,8,10
            8 B video 3
            Shield Shield
            This is measured from original cable. Hope this will help !
              HAMI Vga cable 8 pin Male 15 pin MALE
              mini-din VGA
              1 Hsync 13
              2 R Video 1
              3 Vsync 14
              4 I2C data 12
              5 I2C clock 15
              6 G video 2
              7 GND 5,6,7,8,10
              8 B video 3
              Shield Shield
              You are fantastic!!!!!!!!!!!!!!!!
