10.4" 1200nit , 1024x768 Sunlight Readable, Bonded Touchscreen
  • 10.4" 1200nit , 1024x768 Sunlight Readable, Bonded Touchscreen
    This has to be the best sunlight readable 10.4" on the market :
    The base model is the VT104CHB and this has the following options:
    ♦ Capacitive touch screen with USB interface
    ♦ Optical bonding (better shock protection and better viewing in bright conditions
    ♦ Automatic brightness sensor
    The clear touch coating and special bonding make this monitor perfect for indoor/outdoor applications. It can be viewed under direct sunlight and has an automatic sensor to adjust its brightness. That sensor is movable and has adjustable sensitivity. For video sources, you can use a PC VGA cable or a composite (yellow plug) video cable.
    FEATURES
    ♦ Bright Active Matrix TFT Display
    ♦ XGA 1024 x 768*
    ♦ Anti-Reflective Protective Faceplate
    ♦ High-Bright 1200Nits
    If only I could afford it.
    http://cgi.ebay.com/10-4-Open-Frame-...QQcmdZViewItem
    My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
    no auto turn on, for 200 NIT less, but less than $1000 i'd rather stick with the xenarc 1000NIT.
      Is the Xenarc 10.4" ?
      Is it 1024x768 ?
      Is the touchscreen bonded on?
      All of that makes a HUGE difference.
        my apology, i thought the 702TSV was 10.4", but its actually 7". Aside from that, the bonded touchscreen is nice, but it also has it drawback, when your touchscreen is worn out, you're going to need a new monitor (correct me if that's wrong). Nonetheless, IMHO, i still think there's better options for a nicer monitor, at a much less price.
          I haven't seen a better 10.4" sunlight readable WITH bonded touchscreen at ANY price
          If money is no option I would say this is the monitor to beat.
