Powering my Screen off of M2-ATX?
  • Powering my Screen off of M2-ATX?
    I have an extra plug on my ATX cable, can i use this to power my VM80 screen? The plug has a yellow, red, and black wire. Do i use the red or yellow for the positive?
    Does the screen accept 12vdc?
    It probably does, but I would verify before attempting anything, to prevent the risk of damaging equipment.
    The color of the wires isn't going to help at all.
    How about the Wiki?
      If the screen is designed to run from the cigarette lighter (+12V unregulated) you can connect it to the M2 provided that you have not maxed out the current usage already. Use a voltmeter to verify that the correct voltage and polarity is observed. The Yellow wire of the M2 molex should give +12 and both black wires are ground. You have to figure out the screen end yourself.
      ~Jimmy
        The screens safe power supply: DC 12V (10V-14V)
        Rated Voltage: DC 11.5-14.5(600ma)
        Will this work?
          ive got my lilliput running off of my M2-atx psu just fine.
            Will this work?
            yep
            ~Jimmy
              yeah me too
                in an ATX wire harness, the standard wire colors are BLACK=[GROUND], YELLOW=[+12V], and RED=[+5V].
                Will this work?
                while it certainly wouldn't hurt to power your screen from your M2-ATX, it doesn't appear that you need to if your screen can accept a 10v-14v input.
                F150 Truckputer [1.0] (coming soon!)
                Fusion Carputer [2.0]
                Fusion Carputer [1.0]
                  Me too...works perfectly
                    My lilliput also did support those Voltage's but then connected to the battery it didn't survive it, so i had to get a new one.
                      Powering the screen from your ATX gives it clean regulated 12V. It also guarantees that when the PC is not on, neither is the screen.
                      ~Jimmy
