[Reportage] Backlight xenarc 700tsv 2008
  • [Reportage] Backlight xenarc 700tsv 2008
    HI, is my first message! however I wanted to ask if anyone knows how to control the backlight of 700tsv .. I made a small change with a potentiometer, but are not very convinced of my work ..
    you can't.
      I have really made the change, regulated by a potentiometer .. soon put a fotosensore for automatic luminance
        is possible by changing the card (only) of the screen .. add photos of the amendment ..
          1st! the screen on a bezel bmw
            2nd, the party retail
              3rd, The red mark is the track power of the integration of power
              cut where the black mark
                4th, check that there is more driving .. from condesa jumpered resistance SMD
                  5th, linked by a potentiometer 680ohm or less between the 2nd leg of the aid to the bridge ..
                  resistance 0ohm = max brightness
                  resistance 680ohm = off brightness
                  WARNING! The runway is to cut power, is covered by the power of CCFL, and then generates HEAT!
                  The ideal would be a transistor stabilized!
