LCD Controller help HannStar
  • LCD Controller help HannStar
    ok, Ive just removed everything from an old laptop, and I was planning to use the screen that was in the laptop, but I cant find an LCD controller for it, its an HannStar; HSD150PX14-A.
    Ive got the inverter because it was allready on the laptop, but the controller was a part of the screen card and motherboard.
    So if anyone can help me, please...
    Datasheet : http://www.datasheet4u.com/html/H/S/...nstar.pdf.html
    Google is your friend.
      I already got the datasheed, but I need a control board, on a laptop, its a part of the motherboard...
      So... I just need to find one, if its posible...
      But this is the first time Ive ever tryed this, so Im not shure what to do..
        A good start would be to specify the problem. What outputs does the motherboard you are driving give. If your motherboard has an LVDS port then you may not need a controller board at all. For VGA, component, composite, DVI you will need a controller board, something like (but not exactly like) this: http://cgi.ebay.co.uk/ws/eBayISAPI.d...ksid=p3907.m29
        You're lucky to have a datasheet, it makes the task relatively easy.
