help with flickering lilliput 701 touchscreen in dash
  • help with flickering lilliput 701 touchscreen in dash
    hi,
    i have a car pc with lilliput 701 vga touchscreen in dash
    and i have a flickering problem (when the car is on or off its the same)
    - refresh rate is set to 72Hz.
    - the length of the vga cable is 5 meters.
    - (+) power cable is passing next to the vga cable from the battery (+fuse) to the power supply.
    what can cause this problem?
    what i need to check ?
    If the display is using a CCFL backlight, it could be that it's cold
    Edit: It could be that your power cable is near your VGA cable as well.
    03 Accord Sedan CarPC
      Try moving the power line away from VGA cable. There may be special concerns about how shielded is this vga cable
      Now Galileo is real. Muhahahahaha :p
        i verified that the problem is not on vga
        using a 12v 1.4amp battery connected to the acc and the battery
        the screen looks good without any flickering so the problem must be
        unstable (+) ..
        im sure im not the first one with this problem
        what do you think i need to check \ do ?
          If I understand, your puter is in the trunck so there's a 5 meter vga/usb/... cable. But how's your screen powered?
          Direct from the batt with a short cable (batt->fuse->(POL)->screen) ? or from your carputer's PSU (Batt -(5m)-> psu -(5 m)-> Screen ?
          Where is your scren grounded ? What are the +,- cables gauge ?
