Need Help: Lilliput No-Input Signal
  • Need Help: Lilliput No-Input Signal
    This is my current setup:
    Lilliput GL701-TV/C/T 7" in-dash touchscreen
    Jetway J7F2WE1G5-OC 12w VIA C7 1.5 GHz Processor
    1GB PQI DDR2 533 Ram
    Seagate Barracuda 1TB Hard Drive
    M2-ATX Power Supply
    Mini-Box M300 Case
    Problem: Nearly half the time I turn on the car, the monitor goes to a blue screen with No Input Signal. When this happens the computer fans starts up but I don't get the initial beep to say its loading up. If I manually power the computer down and then turn it back on, I may get video signal or I may get the No Input Signal again. Sometimes I have to restart the computer ten to twenty times before I get a video signal. I can't figure out if it is the monitor or if it is the computer and if it is the computer I don't know if its the bios, the vga card or something else. Does anyone have any ideas or has anyone else run into this problem and solved it. Please help, it's driving me mad!
    BUMP Having the same problem and cant figure out how too fix
