Have a 619 lilliput, need some power on help
  • Have a 619 lilliput, need some power on help
    Just fabricated a 619 lilli in a 2000 4runner... all was well!! until I decided to try and mount the button board behind the dash and cut a hole for the IR receiver. i broke the button board and can't find another one anywhere! I tried the button board from a EBY701 but it doesn't fit the ribbon cable the same. So.. I can't figure out how to turn on the LCD, i've tried crossing lead after lead on the ribbon cable with no luck
    I seen a hack for auto - on for the 619 somewhere, can I do this hack without having the button board? Is it a hack done on the main boarD? if so, please if you guys could, point me in the right direction here, my buddy is howlin' on me for installing a disfunctional system in his 4 runner!
    Age: 18 | Car: Isuzu Rodeo 01 | http://www.mp3car.com/vbulletin/show...s-eee-box.html
    in no means to be absolutely annoying, but does nobody really know?
      the button board is a simple 2 layer board usually. Just solder it back together.
      The button board from a different monitor wont work as you already know.
      Only way to do it from the main board is to emulate the keyboard, which would requiring knowing what is on there.
      1.9in x 2.9in -- 47mm x 73mm
