Any good? -> Lilliput 8" 859GL-80NP/C/TM - 2008 Version
  • Any good? -> Lilliput 8" 859GL-80NP/C/TM - 2008 Version
    I was considering this for an 8" display in my '06 BMW 330CI ZHP. I'd have a custom e46 Bezel fit for this, as long as it would fit in my dash..
    Lilliput 859GL-80NP/C/TM - 2008 Version
    8-Inch 4:3 Stand-alone TFT-LCD Touchscreen VGA Monitor With TV Optional
    4-wire resistive Touch screen: USB (RS232 Optional) interface
    VGA input: 15 pin D-SUB analog RGB interface
    High resolution- up to 1024x768 (H x V) formatted
    Automatic display adjustment
    Full-function IR remote control
    On Screen Display menu control (Multi-language)
    2 RCA video inputs, Audio Input
    PAL/NTSC color system
    Speaker built-in
    High-Brightness LED Backlight
    4 adjustable backlight levels for daytime or night-time use
    Last power setting memory for choice available
    Screen Size: Diagonal 8 "
    Dot Resolution (RGB): 800 X 3(RGB) X 600 (dots)
    Aspect Ratio: 4:3
    Contrast: 500:1
    LCD Brightness: 350cd/m2
    Viewing Angle: 45/60(U/D),65/65(L/R)
    Operating Voltage: DC 11-13V
    Power Consumption: <10W
    Dimension (mm): 202W x 154H x31D
    Weight (kg): 0.708
    It can be found here.
    Anyone have any opinions on this one, or know of a better model in the 8" size?
    I have this LCD too
    When Im talking with lilliput(Jenny) she tell me that operating temperature is -15 C to 60C,( but the -20C to 70 C is Critical point).
      Sooooo...
      -20 degree Celsius = -4 degree Fahrenheit
      to
      70 degree Celsius = 158 degree Fahrenheit
      Sounds like no trips to the Sun for me!
        lol you have 70C in car when you drive? I don't think so
