Noise in video Lilliput's signal
  • Noise in video Lilliput's signal
    Hi all. I have some slight noise in my video signal, visible as moving horizontal lines when the screen is displaying a solid color (esp black). I don't think this was the case before I put the guts inside my MoCoSo case (which has a fan integrated).
    Has anyone seen video noise caused by noise inside the case, or just along the vga cable? I was considering trying a ferrite donut around the cable, but am concerned its from inside the case. Any tips would be greatly appreciated.
    The video by the way is from the onboard chipset on an intel d945gclf2.
    Thanks for any tips...
    // 2008.5 CWP MAZDASPEED 3
    // mp3car showoff thread
    // appearance & performance mods
    // computer setup
    if your running your sound cables alongside the video cables your going to have interferance.
      Thanks for the thought. The RCA cables are running parallel about a foot away from the VGA cable. Do you think a donut would help?
      // computer setup
        Actually, you want to keep all signal cables (audio & video) away from power cables.
        If you get interference from audio and video cables next to one another, then there's some other problem.
        How about the Wiki?
          i would run the vga cables down the middle of the car, Power on the left and audio on the right.
            I have the same problem.
            There is no lines / noise when I use the AC power adaptor.
              I ran all audio and video down the middle, then power on the right side of the car. i have no noise at all untill I turn on the A/C Blower. Then I see slight lines but not that noticable.
              1X Ainol Novo Flame Tab
              4X MK808b
              3x Perixx Touchpads
              3x 7 inch Screens
              1X 7 inch motorized Screen
              1x Win 7 PC
                I get hazy horizontal lines, but when I press on my brake pedal, they go away...go figure
                Sig, smig...
                Ford Flex Toshiba Excite 7.7 Install
                CoverMess - Cool Flash Covers
                FlashFlex - Flash Components for your skinning pleasure
                Mazda Millenia, Road Runner
                YouTube - Road Runner, IGO8 PC, Dashcommand OBD, Visteon HD Radio
                  All of my cables are ran together and I had the lines at first, but a ferrite loop fixed the problem.
                  Speaker cable can be ran by power, just not low-level audio cables(i.e. rca cables)
                  xb_mini
                    i must sound like a complete idiot but whats a ferrite loop?
                      are you powering the screen off the computer's power supply, or running a seperate line to it? I had a lot of interference and noise issues until I powered my screen from the same psu as the computer.
                        Its whats inside of the plastic ring by the end of a lot of cables.
                        http://en.wikipedia.org/wiki/Ferrite_bead
                        I guess the technical name is "ferrite bead".
                        xb_mini
                          Look HERE
                          If you cant DODGE em, RAM em.
                            For folks that have used them -- what size and did you place it over the cable toward the screen end or the psu end? I'm asking only because digging out the cabling is not going to be easy...
                            // computer setup
                              http://www.mercola.com/forms/ferrite_beads_howto.htm
                              That might help.
                              I think you should probably put it closer to the end that you think is causing the noise. I put mine close to the power supply.
                              xb_mini
