lilliput 629 - no input signal problem
  • lilliput 629 - no input signal problem
    hello,
    i had a lilliput 629 touch screen in my car with a running carpc,
    i decided to upgrade it to a new pc:
    motherboard: gigabyte GA-G31M-ES2L with intel cpu
    psu: m4 250W
    memory: 1 gigabyte
    i tried to run it at home and it worked great.
    i tried to run it at the car and i got:
    black screen, and then "no input signal" msg and then black screen again ...
    endlessly.
    i tried to connect a laptop to the vga cable and it worked great too.
    so the cables are good, the screen is good, the pc is running on a normal screen at home,
    what im doing wrong?
    thanks, nir.
    Do you get any thing on the lili.
    Menu?
    VGA no signal message?
      Originally posted by poz View Post
      hello,
      psu: m4 250W
      memory: 1 gigabyte
      endlessly.
      thanks, nir.
      I just had this problem. You need to really shove the video wires together. I mean literally as hard as possible.
        but i used a laptop connected to the vga from the back of the car until the screen and it worked just fine,
        its not enough to know that the connection is good?
        where do you mean to really shove it, on the motherboard itself?
          problem sovled!
          it was the vga connector that connects to the pc itselfs
          i pluged it again and closed it with the the screws
          and it works!
          thanks for your help!
