Has anyone tried a usb printer adapter for a parallel LCD?
  • Has anyone tried a usb printer adapter for a parallel LCD?
    I've heard people say it will work, and people say it won't work. What I want to know is some concrete proof either way
    I'm trying to smooth out my wiring scheme for my din control box and so far it looks like i'm going to have to run way more wires than I was hoping.. this would significantly reduce that. (keyboard, usb, ide, parallel, power)
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    I'm using one to drive a printer here at work, and from what I see - the answer is that it won't work.
    USB LPT adapters don't emulate a hardware printer port - they add their own software LPT port. LCD's require hardware level access to the printer port in order to send control codes.
    I know it's not the concrete "failed attempt" that you're looking for, but that's pretty much what we figured out a year ago.
    If somebody begs to differ, I'd like to see it.
      sounds good enough for me.
      Better than "It won't work" "You're wrong, it will work" with no kind of logic
      aka Kumaneko
        That sucks. I was thinking that they would work. My shuttle doesn’t have a parallel port. Now I have two parallel LCD's and no way to use them.
        Comp. Specs:Shuttle SS40G, Athlon XP 1700+, 256MB DDR, 40GB HD, Belkin Desktop 802.11b card (good range), SB 128 sound (onboard is a bit noisy), DVD ROM
        Toshiba 100CS laptop, P75 40mb ram, 550MB HD, Megahertz LAN/modem PC card, modified to run off 12VDC
        Other stuff:Generic USB hub & USB to serial adapters, BS2SX power control system w/battery buffer, Jazz 300W Inverter, FM Modulator, Palm Vx, & GPS
        Status: 80% complete (Almost done with the controle boxes)
          try this one
          http://www.futurlec.com/USB.shtml
          (the second one)
          that should work. It comes with software to emulate the port. I got the serial to usb one, well ordered. So you can use the software driver to emulate port 1 and 2 thru the usb.
            That third module seems like it would be ideal if i were smart enough to figure out how to make it control my applications
            If I follow you correctly, this device should be able to handle 2 devices? And as far as I can tell, you solder the connections, is this correct?
            aka Kumaneko
              well the module converts one device to usb. basically a serial (or parallel) to usb converter without the covers and stuff. You can buy a parallel connector and solder it to the converter and plug your device to it so you can reuse it.
                The next problem would be writing software that would interface with that USB device to drive your parallel LCD. Perhaps you could write a plugin that would work with the Zhender Winamp plugin - that would be pretty sweet.
                  well the software would've came with the lcd. the usb drivers just emulate the port so no need for extra software, just tell the lcd software which port.
                    ULLER said it wouldn't work
                    http://www.hardforum.com/showthread....hreadid=572298
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
