Lilliput auto video switching for reversing camera
  • Lilliput auto video switching for reversing camera
    I have been reading a lot of posts about the Lilliput not being able to 'auto switch' even though it is in the secret menu, so I decided to make a small circuit that would switch the screen to Video1 when reverse is selected and back again when out of reverse. It uses a Pic microcontroller to do the job.
    At the end of this post is the assembly code for the PIC16F690. I used MPLAB IDE to program my PIC.
    The relays I used were small PCB mounted relays to make the circuit nice and small. Mine ended up in an enclosure about 50mm x 40mm x 30mm.
    Here is a link to the 5 volt relay I used:
    http://uk.farnell.com/jsp/search/pro...sp?SKU=1175716
    The circuit diagram:
    How it works:
    When reverse gear is selected, the 12 volt relay is energised which in turn 'grounds' input RA2. The PIC then 'sees' this and pulses the 5 volt relay on for 0.5 seconds and the off again.
    When you take the vehicle out of reverse, the PIC 'sees' RA2 go 'high' again and pulses the 5 volt relay once again.
    After each relay pulse, the PIC waits for 3 seconds before it checks the input on RA2 again. This pause is needed, as if you select reverse and then back to drive again quickly, the Lilliput hasn't had time to settle on its new AV input, and it doesn't react to the relay pulse.
    Also, when the circuit is first powered up (when the Lilliput has power), the PIC waits for 3 seconds to allow the Lilliput to start and before it starts reading the input on RA2. This is in case you are in reverse gear when the Lilliput is powered. After 3 seconds, it starts reading the input and if you are in reverse, it will obviously change the AV input.
    Hope this is helpful.
    The assembly code:
    ; Reversinmg camera controller ;
    ; Author: Craig Smith ;
    ; Date: May 2009 ;
    ; 4MHz internal resonator used ;
    ; RA2 - input via 12 volt relay (high if not in reverse, low if in reverse) ;
    ; RC1 - output to turn on 5 volt relay to pulse the AV button on Lilliput ;
    ; When the circuit is energised, there is a 3 second time delay to allow the Lilliput screen ;
    ; to become 'active'. If RA2 is low, that means reverse is selected and the DebounceRev sub ;
    ; is called, if it is low for a 256 count we must be in reverse, so RC1 is pulsed on for 0.5 ;
    ; secs and then off. Video 1 should now be selected on the Lilliput. 3 second pause then.. ;
    ; Now we wait for the input to be high and do a debounce and if the input is hight for a 256 ;
    ; count we are out of reverse and the 5 volt relay is pulsed again for 0.5 secs and pause ;
    ; for 0.5 second to change the Lilliput back to PC mode. ;
    ; If the last change was 'reverse', the program loops around CheckDrive until the van is out ;
    ; of reverse and then it loops around CheckReverse until the van is in reverse..... ;
    #include <p16F690.inc>
    __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
    cblock 0x20
    Delay1 ; delay loop 1
    Delay2 ; delay loop 2
    Delay3 ; delay loop 2
    TimeDelay ; register used to set the time delay (x 0.01 secs)
    Temp ; used to hold termory values
    Count ; count register
    endc
    org 0
    goto Start ; jump to Start
    ; Subroutines are here at the top ;
    ; The Delay routine is called with a number put into the TimeDelay register. This is in ;
    ; multiples of 0.01 seconds ;
    Delay:
    movfw TimeDelay ; put the TimeDelay into W
    movwf Delay3 ; put W into Delay 3
    Loop1: ; After Delay2 decreses to 0, it is reset to..
    movlw 0x0E ; put E into W
    movwf Delay2 ; put W into Delay2
    Loop2: ; After Delay1 decreses to 0, it is reset to E9h
    movlw 0xF0 ; put E9 into W
    movwf Delay1 ; put W into Delay1
    Loop3:
    decfsz Delay1 ; decrement Delay1
    goto Loop3 ; jump back to Loop3
    decfsz Delay2 ; decrement Delay2
    goto Loop2 ; jump back to Loop2
    decfsz Delay3 ; decrement Delay3
    goto Loop1 ; jump back to Loop1
    return
    ; Change State pulses the relay for 0.25 seconds and then waits for 1 second ;
    ChangeState:
    bsf PORTC,1 ; set RC1 to 1
    movlw 0x32
    movwf TimeDelay
    call Delay ; 0.5 sec delay
    bcf PORTC,1 ; set RC1 to 0
    movlw 0xC4
    movwf TimeDelay
    call Delay ; 2 sec delay
    movlw 0x64
    movwf TimeDelay
    call Delay ; 1 sec delay
    return
    ; Main program starts here ;
    Start:
    bsf STATUS,RP0 ; select register page 1
    movlw b'00000000' ; put 00100000 in W register
    movwf TRISC ; portC all outputs
    movlw b'11111111' ; put 11111111 in W
    movwf TRISA ; PORTA all inputs
    bsf STATUS,RP1 ; select Page 2,
    bcf STATUS,RP0 ; by setting RP1 in Status register and clearing RP0
    clrf ANSEL ; select Digital I/O on port C
    clrf ANSELH ; " "
    bcf STATUS,RP1 ; back to Register Page 0
    clrf PORTA ; clear PORTA
    clrf PORTC ; clear portC
    StartDelay: ; 2 second delay
    movlw 0xC8 ; put C8 (200) into W
    movwf TimeDelay ; put W into TimeDelay
    call Delay
    ; 1 second delay
    movlw 0x64 ; put C8 (200) into W
    call Delay
    CheckReverse:
    btfss PORTA,2 ; see if we are in reverse
    goto Reverse ; Reverse
    goto CheckReverse
    CheckDrive:
    btfsc PORTA,2 ; see if we are in drive
    goto Drive ; Drive
    goto CheckDrive
    Reverse:
    call ChangeState ; call the change state relay sub
    goto CheckDrive
    Drive:
    goto CheckReverse
    end
    Sorry the code is so jumbled, but the forum doesn't like tabs in the text
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    thankyou for sharing this me and a friend were just starting to work on this ourselves.
      Thanks for sharing your work.A quick question ,would it be a simple matter to have the circuit pulse twice when reverse is deselected,my monitor needs two presses to get back to vga.
        I only need one pulse to change into reverse and out, because in the secret menu on the Lilliput I have deactivated VIDEO2.
        Here is a slight update to my PIC code. The sub 'Drive'
        Drive:
        ; 3 second delay, becaues when the car is taken
        ; out of reverse, the camera is de-powered, and
        ; the screen takes a few seconds to steady
        ; before we can switch
        movlw 0xC4
        movwf TimeDelay
        movlw 0x64
        movwf TimeDelay
        goto CheckReverse
        I had the problem that when the van was taken out of reverse, obviously the camera is de-powered, and the Lilliput takes a couple of seconds to adjust to the 'no-input' before it can be switched.
        This way of making the Lilliput auto-select may not be the best way of doing it, but it is all that I could come up with, and it seems to work OK.
        7" Lilliput
        120Gb Sata drive
        1GB RAM
        (Always tweaking!)
          this is exactly what i needed. can you tell me where to get the pic, and how to hook it up? programming the pic isn't a problem.
            Hi,
            This looks as something as I would like to implement into my car also. Just one question regarding the de-power issue, canīt you connect one of the inputs on the PIC to the reverselight and then power the camera from an additional output on the PIC? this way you donīt need to wait for the "No input" screen.
            // Tom
            Gallery of my cars (current and old ones)
            Nissan 200SX project @ mp3car
            My old car, VW Passat Variant V5 @ mp3car
            My modified Kuo skin, named Kuo Blue
            Speedtest result
              Probably would have been better, but I had a hard enough job getting the cables back to where the camera is, as the reversing camera was an afterthought, and I don't like continually taking all the ceiling panels and interior out of the van.... As you can see from the finished pictures of my van
              http://www.mp3car.com/vbulletin/show...5-pimping.html
              7" Lilliput
              120Gb Sata drive
              1GB RAM
              (Always tweaking!)
                But maybe you could make the software in the PIC support in/out for reverse/camera
                // Tom
                Speedtest result
                  How do you get to the secret menu of the lilliput to deactivate video2. I dont have the button board for my lilliput. Would anyone know where to solder gor the av select button. On the board solder would be fine, or splicing into the button board connecting cable would be better. Also Tom, if what your suggesting works, would there be a change in his code and how to wire it.
                    Yes on all questions, it works, coding is needed and rewiring is up to how portreathbeach codes it.
                    // Tom
                    Speedtest result
                      But how do you get to the secret menu? Also about the button board, as stated i do not have one, would you know the diagram for the wire so i can splice into it for the av select buton?
                        That I on the other hand donīt know anything about. Donīt even own a liliput screen but this electronics can be used with other monitors aswell...Works with same principle, press AV button, monitor changes to AV1, AV button again and we go to AV2, AV btn, AV3, AV btn and back to AV1 for example...
                        // Tom
                        Speedtest result
                          did you make this by putting it on a circuit board and soldering the PIC and the 5v relays on to it? could you post a pic of what you have done? also what kind of 12v relays are those?
                          for consideration, can't you just power the camera through something else like the license plate lights instead of the reverse light. sure the camera stays on, but it doesn't matter rite? that way you wouldn't have the de-power issue because the camera doesn't turn off.
                            any 5v pcb relay should be fine correct?
                              moto_noob - To get the 'secret menu', use the Lilliput IR controller and press Menu, then 5,8,8,9,9,8.
                              Sorry, I didn't take any photos of the circuit I built. I used vero board (stripboard) and soldered a 20 pin ic holder to it for the PIC and the various other components also. The relays I used were simple PCB mounted relays.
                              In my first post I gave a link to the 5 volt relay I used:
                              www.farnell.com
                              5v relay - item number 189023
                              12v relay - something similar to item number 1652598
                              Any 5 volt and 12 volt relays should work, but PCB mounted relays are smaller and make for a neater job.
                              Hope this is useful
                              7" Lilliput
                              120Gb Sata drive
                              1GB RAM
                              (Always tweaking!)
