Lokking for a screen between 10.3" and 10.6"
  • Lokking for a screen between 10.3" and 10.6"
    Sorry for bad english, I'm for Norway.
    I have a perfect space for a screen in my car that measures 228x112mm.
    This is a size that is "17:9" or something, so I know I can't have that. However there is enough space inside the frame to use a screen that is bigger, if I can live without seeing the whole screen.
    If I'm gonna use a 16:9 screen it have to be at least 10.3" (228x127mm), but I think it would be better to have a screen that is a little bit bigger than my frame all the way, so a 10.5", 10.6" or something would be perfect. However I can't find any screens for a normal price in those sizes.
    I have also looked at notebooks (netbooks?), but most of them are 9" and the biggest are 10.2". It don't mind to brake one of those to get what I want, as long as it's possible to extend the screen wire.
    Does anyone have a suggestion for a screen? It doesn't need to have a touch function as long as I can add an overlay touchmat or something.
    Another question, is there software that could "make" a 10.3" picture on a 10.6" screen? Just leave the fields around blank.
    Edit: could someone change to topic from "lokking" to "looking"? It went a little fast when I was typing.
    You can get a 10.4" screen
    For example >
    http://cgi.ebay.co.uk/10.4-Inch-Touc...QcmdZViewItemp
    Hope that helps
    Mileage Calculator and logger in progress check it out :)
    http://img.photobucket.com/albums/v4...italcarsig.jpg
      Thanks, but they are all 4:3, I need a 16:9 (widescreen).
        buy an eee pc =P and and a 4-5wire touch
        http://eeepc.asus.com/global/products.html?n=0
        http://www.bestofferbuy.com/Touch-Sc...campaign=gbase
        100% cheapest/easiest way to get a 16:9 10"
        that i've found
        Edit: 10.2" I think you'll be fine with loosing a mm or two lol
        Edit2: The cheapest you will find it/ this is a good company to deal with
        http://www.geeks.com/details.asp?Inv...EPC1000-W004-R
        so your looking at spending 390$ s&h included
          I have tought about that, but a 10" screen is 10mm shorter than my frame, that would make 5mm on each side, and will not look that good.
          Edit: I need to learn to read everything in a post. Maybe I could live with loosing 1 mm on each side.
          Maybe I can modify the frame somehow or something, I'll look in to it.
            you could mold the pcs screen and frame in the bezel that would be the best looking way I think
