Xenarc 700IDT in-dash fitment
  • Xenarc 700IDT in-dash fitment
    I'm looking into the possibility of a carputer for my Miata, and have a couple of questions about this in-dash monitor.
    First, I've read that although advertised as fitting a standard DIN opening in fact the unit is actually a little too large to fit without modifications. The posts I've seen regarding this are a few years old now, and I wondered if Xenarc might have addressed this problem on their newer units.
    Secondly, as can be seen in the pics my head unit protrudes about 1" from the dash. Would it be possible to mount the screen in the lower DIN slot, or will the head unit's encoder knob interfere with the back of the screen or prevent it from opening properly. I'm concerned that if I mount the screen in the upper DIN slot I will cover the air vents above it.
    - Rock
    Morex 3688
    MII 12k 512Mb
    M1-ATX
    Toshiba 60g hd
    Panasonic DVD RW
    iGuidance w Bu-353
    Lilliput 619 TS
    I have a 700IDT:
    http://www.interforcesystems.com/pro...e/P6180006.JPG
    http://www.interforcesystems.com/pro...e/P6180008.JPG
    As you can see it fits in a single din opening perfectly fine. My screen also sticks out a bit, and while the screen does touch it, it does not prevent it from opening. The screen itself sticks out about an inch when closed and that is the hinge point.
    RevFE
    My Shop
      Thanks, Malcom - that's just the confirmation that I was looking for.
      - Rock
      Morex 3688
      MII 12k 512Mb
      M1-ATX
      Toshiba 60g hd
      Panasonic DVD RW
      iGuidance w Bu-353
      Lilliput 619 TS
        Something of note, if you have a support bar in the back of your DIN opening, you may have to use the barrel plug power connector as opposed to the 4 pin power connector just so the unit seats all the way in the slot.
        RevFE
        My Shop
          Thanks for the heads-up, Malcom. As you might imagine, the Miata is going to be a pretty tight fit all the way around. As it is, I just barely was able to get the aftermarket HU all the way in. Thanks again,
          - Rock
          Morex 3688
          MII 12k 512Mb
          M1-ATX
          Toshiba 60g hd
          Panasonic DVD RW
          iGuidance w Bu-353
          Lilliput 619 TS
