Roof Mount
  • Roof Mount
    Im planning to mount a screen on the roof
    for the back seats
    The problem im having is does anyone know
    what those hinges are called where
    you either press or push and the screen slowly
    opens down?????
    Ive been searching for hours and cant find
    any of those hinge/latches anywhere
    Thanks!
    Is it just a spring loaded hinge
    with a latch?
      for the back seats
      opens down?????
      Thanks!
      Are you making the screen to a roof mount screen? If it is built as a roof top screen, then it doesnt use that because of the weight of the screen. Most use this metal rod that is shaped like a stop sign and then little metal tabs pieces to latch into the stop sign shapped rod. They do it for durability of the hinge.
      PS: i know what your talking about, its basically a gear system that puts restance on the screen so it opens slowly. I cant recall the name either though. Closest thing would be maybe a damper hinge? http://www.directindustry.com/prod/s...87-382465.html
      1X Ainol Novo Flame Tab
      4X MK808b
      3x Perixx Touchpads
      3x 7 inch Screens
      1X 7 inch motorized Screen
      1x Win 7 PC
        Thanks HiJackZX1
        Yeah the gear system
        Where you push the item in it unlocks and
        opens on its own (slowly) and then you can
        push it back in and it locks
        Please does anyone know what its called
        and where I can get them????
        Still cant find it
          They are called 'damper hinge' as far as I know it
          Actually... what you want is a reversed damper hinge.
