Intel G965 graphic custom resolution 800x640?
  • Intel G965 graphic custom resolution 800x640?
    The chip is Intel G965. Any way you can make a customized driver that supports this resolution 800x640?
    Since I have a 19 inch LCD. Thanks.
    I don't know how but a quick search came up with these threads:
    http://www.mp3car.com/vbulletin/lcd-...ssible-14.html
    http://www.mp3car.com/vbulletin/lcd-...-graphics.html
    They're not the exact chip you have but they may be able to show you what you are looking for.
      Thank you for your reply.
      The resolution is different. Mine quest is to set 800x640 and the topics are about 800x480.
      BTW: the information of the monitor
      Monitor
      Model name............... HN199D
      Manufacturer............. HannStar
      Plug and Play ID......... HSD0777
      Serial number............
      Manufacture date......... 2006, ISO week 11
      EDID revision............ 1.3
      Input signal type........ Analog 0.700,0.300 (1.0V p-p)
      Sync input support....... Separate, Sync-on-green
      Display type............. RGB color
      Screen size.............. 380 x 300 mm (19.1 in)
      Power management......... Standby, Suspend, Active off/sleep
      Extension blocs.......... None
      DDC/CI................... Not supported
      Color characteristics
      Default color space...... Non-sRGB
      Display gamma............ 2.20
      Red chromaticity......... Rx 0.634 - Ry 0.339
      Green chromaticity....... Gx 0.285 - Gy 0.587
      Blue chromaticity........ Bx 0.144 - By 0.075
      White point (default).... Wx 0.310 - Wy 0.330
      Additional descriptors... None
      Timing characteristics
      Horizontal scan range.... 31-81kHz
      Vertical scan range...... 56-75Hz
      Video bandwidth.......... 140MHz
      CVT standard............. Not supported
      GTF standard............. Not supported
      Preferred timing......... Yes
      Native/preferred timing.. 1280x1024p at 60Hz (5:4)
      Modeline............... "1280x1024" 108.000 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
      Standard timings supported
      720 x 400p at 70Hz - IBM VGA
      640 x 480p at 60Hz - IBM VGA
      640 x 480p at 72Hz - VESA
      640 x 480p at 75Hz - VESA
      800 x 600p at 56Hz - VESA
      800 x 600p at 60Hz - VESA
      800 x 600p at 72Hz - VESA
      800 x 600p at 75Hz - VESA
      1024 x 768p at 60Hz - VESA
      1024 x 768p at 70Hz - VESA
      1024 x 768p at 75Hz - VESA
      1280 x 1024p at 75Hz - VESA
      1280 x 1024p at 60Hz - VESA STD
      1024 x 768p at 72Hz - VESA STD
      Report information
      Date generated........... 8/30/2009
      Software revision........ 2.30.0.797
      Operating system......... 6.0.6002.2.Service Pack 2
      Raw data
      00,FF,FF,FF,FF,FF,FF,00,22,64,77,07,22,08,00,00,0B ,10,01,03,0A,26,1E,78,EA,71,D6,A2,56,49,96,24,
      13,4F,54,AF,CF,00,81,80,61,4C,01,01,01,01,01,01,01 ,01,01,01,01,01,30,2A,00,98,51,00,2A,40,30,70,
      13,00,78,2D,11,00,00,1E,00,00,00,FD,00,38,4B,1F,51 ,0E,00,0A,20,20,20,20,20,20,00,00,00,FF,00,20,
      20,20,20,20,20,20,20,20,20,20,20,20,00,00,00,FC,00 ,48,4E,31,39,39,44,0A,20,20,20,20,20,20,00,FB
        a similar problem i had with the same chip ...
        i did alot of research about it, but as far as i can racall this graphic adapter doesnt support this resolution , however theres a nifty program called "power strip" it might do the trick , i remember i was playing around with it, but i dont remember what the result was .. it was a couple years ago, however its woth a shot, keep in mind that if power strip cannot output the desired resolution then the adapter simply cannot output it ...
        2007 Toyota Tundra Double Cab SR5
        >"Say what you mean and mean what you say"<
          also, u might find something useful here : http://downloads.guru3d.com/download.php?id=17
          here i found a hacked driver for my ATI card that opened the options i needed...
